Rat Bastid
Dunamis Metron
On ethanol based fuels. If you scroll down and read the comments you will see a staunch defender of ethanol. I will download and read his book.
I think ALL pump fuel should be 25-30% ethanol. It will reduce emissions, allow higher compression ratios and won’t require too much of a tune up change.
“What I Learned Today” With Jeff Smith — Ethanol Isn't The Bad Guy
