Vin Stamp 1968 383 location
johnnycuda
JohnnyCuda's 68
Pass side above oil pan on block should match Vin?
Should i also check casting numbers?
Its a 1968 Formula S 383 4 spd car
1 of 154 i think
It’s the one i told you guys about from gas monkey Garage
Spoke to Richard today about the car.
I was asking him where to look it was on the lift when i was on the phone with him but he couldn’t find it not sure if i told him the correct location or not im pretty sure thats correct. Thx in advance
So i thought it was passenger side pan rail like the 1970 Road runner i had
I thought (could be wrong) that you may not find it there on '68 blocks. Just starting out ya know. I would look along the back of the bellhousing area for numbers too, near the end of the oil galley ports, on a 68.
Front pad and casting might give you some important dates as well.
Not my picture, but this small block is in the same general spot.
On my '68 383 Road Runner, the VIN stamp was on the block near the oil pressure sensor.
That's not the vin number, that's the sequence number. You need the build sheet to tie it to the vin number. And yes, it's on the top rim where the Trans mates. It should also be stamped there on the transmission also.
Definitely the VIN. You can stand there and look from the VIN plate on the dash and look down to the engine and trans and see they match.
I found my pics. You can see 8B for 1968 and Hamtramck and then the sequence number.
