Ok, just finished hanging my exhaust, fired up the engine. Man, this thing sounds good with those Ultra Flows! The problem I'm having is, with the trans in gear, the car will roll like it's in neutral. I took the driveshaft out, installed a spare tranny yoke, took the slave cylinder off the clutch fork to ensure the clutch was not engaged, disconnected the shift rods and manually (no pun intended) shifted into gear. The output shaft still turns. WTF is going on? Help, before I put an automatic in this rig! BTW the tranny is a '75 Overdrive. The car is a '71 Duster, small block.
