72Duster440
And pulled less power than I was expecting. It was sure blowing the carbon out of the motor though on the first couple pulls.
Here's the specs that I know on the motor, I haven't done anything to it since I got it.
1967 HP 440 BLOCK, RODS AND CRANK
FORGED TRW FLAT TOP PISTONS
572 CRANE CAM
915 CLOSED CHAMBER HEADS, PORTED, POLISHED AND FLOWED
2.14 INTAKE AND 1.81 EXHAUST VALVES WITH DOUBLE SPRINGS
MOPAR PERFORMANCE SINGLE PLANE INTAKE
HOLLEY 780 VACUUM SECONDARY CARB
2 PRIMARY LONG TUBE HEADERS WITH HOOKER MUFFLERS
MSD 6A IGNITION BOX
One thing we did notice on the last pull, above ~5500rpm the fuel pressure dropped to 1-2psi, but even at idle I can't get it above 5psi regardless of where the regulator is set. I also noticed that the fuel filter after the pump barely has any fuel in it.
Would this be a puel pump on the way out?
572 CRANE CAM
MSD 6A IGNITION BOX
