I thought this was the ECU? The voltage regulator does have some markings on it but the one on the fire wall has nothing visible.One is your voltage regulator, the other is the ECU box! I would replace them!!!
Yes.EGR timer delay on the right in OP?
So since i took out the egr will it upset anything if i removed the timer delay?Yes.
Either 60 or 90 second delay. If you already removed everything, it is not doing anything, but I would check your wiring schematic to be sure another system is not affected.So since i took out the egr will it upset anything if i removed the timer delay?
what is the ETC timer for?Either 60 or 90 second delay. If you already removed everything, it is not doing anything, but I would check your wiring schematic to be sure another system is not affected.
Something like this
Thank youChoke.
Tell you what?Appears to be one of the last A-bodies, maybe 1976, w/ 318 V-8. Why not tell us?
Sorry. Why not tell us the year, model, and engine when asking such a question? That will help everybody, and you. Your engine bay doesn't look like most A-bodies here.Tell you what?
Sorry i have started about 3 threads and i forgot where i put the year of the car. It is a 75 dart swinger 318 California car. I mention California because they were a little more strict with emissions back then. The car HAD a full egr system w/ A.I.R pump. Why do you think the engine bay does not look like the other A bodies on here?Sorry. Why not tell us the year, model, and engine when asking such a question? That will help everybody, and you. Your engine bay doesn't look like most A-bodies here.
Your referring to the ECT timer? So is it accurate to say that there is 2 timers in the engine bay. The one on the fire wall is removed. The voltage regulator is the one on the fender then there is one just out of the picture farther up on the fender that is the on i am asking if it is the ECT timer. That one is still in the car. I do not know if i need it or not, since the egr system is removed.The timer prevents the EGR system from operating until the car is off choke.
