What do i need??
brandon2701
brandon2701
HAWAII
I have recently acquired a powerdyne BD-600 supercharger and was about to put it on my bonestock LA 360 which is in my '68 Dart 270, but wanted to know if there is anything to it or is it really as simple as acquiring all the right parts and throwing it on?? I do not kno the psi and do not know anything about superchargers please help me out, thanks in advance, Brandon.
you are gonna need a cam that is friendly to it and thats all I know. I've seen these used on 289 engines and V-6 engines, I'm not too experienced with blowers or forced induction so here's a free bump. I'm sure someone with the smarts will step in and help out :cheers: theres a guy running a paxton supercharger of the same or similar style on here on a 340. Pretty sure he has aluminum heads and forged internals
This by no means complete, but it's similar to what you want to do, and it'll get you started (or, run you off.):angry7:
My 360 Magnum/Vortech V-1, S-trim build: 10 # of boost, 445 rwhp
Will run mid-11s @ 118 mph in the 1/4-mile with 4.10 gears and 9"-wide, 28" tall, tires, if the bite is decent. 3,300# car with a 904
New Vortech blower from ebay: $1,000.00
Product Engineering fuel regulator: $ 250.00 (estimate)
Carb (blow thru modified) CARB shop $900.00
Fuel system (2 pumps, filters, 1/2" push-on lines, A-N fittings, $800.00)
MSD ign. components (Boostmaster. coil) $400.00
Spark Plug wires $80.00
8.75" rear with Moser axles and new 4.10 limited slip $1100.00
904 with hi-stall converter $750.00
Dist. $100.00
New driveshaft with (larger) 7290 u-joints $375.00
New radiator; 3 row $290
Vacuum reservoir for pwr brakes $100.00?
Turbo action shifter $300,00
Cam (Hughes) $400,00 with springs
Roller rockers $300.00 Crane???
Bottom pulley donated
Serpentine blower-belt Hell. I don't remember... sorry
Mounting plate (my design/friend fabbed it $150.00)
TTI Headers $585.00 coated
Rest of TTI exhaust system around $450.00 estimate
Boost gauge $25.00
Supercharger lube oil, oil filter $60.00???
Snowperformance Boost Cooler meth injector $200.00 (they've gone up to $300.00, now...
Stock 360 Magnum out of a Durango (lo-miles) $1100.00
B & M flex plate $95.00
Rust-free '72 Valiant 4-door $100.00 ( No typo)
Wheels $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Good luck!!!!
