What modern tire size to replace E70-14s?
Any chance that is streetlegal?
And 275 might be a bit narrow for a 10 inch wheel :(
Yes, It is full tread and DOT legal.
Most guys, especially on here run narrow wheels for a given tire. You don't want a ton of sidewall past the rim. It's bad for handling and it's bad for straight line traction. As you run a wider wheel it flattens the tread surface at any given air pressure.
That hoosier is 10.10" section width in an 8" wheel. So it would certainly work on a 10" wheel. It would just be wider and function better.
I run a 13.10" section width tire on an 11.25" wheel for reference.
good
the two things i would worry about is the bead not seating properly...and looking like those jackmonkey VW owners
Try Pro-Trac. Think they still carry the N50-14.
great, ill give them a call
thanks
good
you won't look like a jackmonkey lol
Heres that wheel and tire combo.
Thanks rocco, that does look good
(i was worried to see something like this)
