65sat
One of each?!
It had been a minute since I worked on a front hub/drum, so when I popped the driver side front wheel off this 65 barracuda and found a drum and independent hub, I rolled with it. Went to the other side and assumed it was stuck and wailed on it several times til it dawned on me lmao....
I assume it's an old repair shop job. Anyone know just from photos what this setup might be? The car is a 2bbl 273 auto, I got a 4bbl hp 273 parts car and scavenged some parts from the front hub drums, but unfortunately the rear had the bigger HP drums, so parts car hasn't been much use in the brake dept...
