Which centerlink is this for?
Looks like maybe a slant 6 centerlink. Maybe a 1967 based on the bolt that goes through the pitman arm.
That is really just a guess maybe someone will confirm.
Hrd to tell from that angle but I think you are correct year wise...really cant tell if the drivers side dips lower.....from that angle could be either...front on shot would tell the tale
Most likely a 67-72 A-body centerlink. Same for /6 and V/8. That bolt through idler is 68-72 if its for an A-body. 64-66 and 67 idlers had a stud in them that went into the K-member.
There is no such thing as a /6 only or V/8 only centerlink for a 67 or newer A-body.
But, it could be a 64-66 A-body centerlink. Those came in /6 and V/8 versions. The length is different than the later ones. I don't know the measurements.
