pearljam724
Can a 360 engine and automatic 904 from a 76 Dart be easily swapped into a 72 Plymouth Scamp with an automatic slant 6 ?
Where's the B body part come in?
Are you saying the K member has to be swapped ?HUMmmmmnnnn// or swapout the v8 K and suspension?
NO I am saying that.... maybe the V8 suspension would be more worthwhile. It is not that hard to changeout the K and thus suspension. You need v8 suspension? as is maybe discs, T bat, etc?????Are you saying the K member has to be swapped ?
Yes, swap it all. It is just 4 bolts, plus disconnecting the torsion bars and upper control arms. It will be easier, cheaper and less work than trying to cobble up motor mounts and suspension parts.Are you saying the K member has to be swapped ?
