Here you go! I've just widened the rear of the body from the middle of the doors back. I cut the original 1/4 panels of as narrow as possible then cut the donor 1/4 as wide as possible to give me some extra width. I had to cut the doors out about half way as well then slice the new panels slightly so I could bend them in to match the original body. By cutting the doors the way I did it always a smooth tapered flow between the 2 different width's. The total gain in width is 1/8" on each side plus I've also sanded the inside of the 1/4's down for even more clearance (the body mold is very thick on this). I now of course have to widen everything else that go with the body (tail light panel, bumper. floor pan, etc.), but by cutting it the way I did the interior with is unchanged as I left top portion of the original doors in place.
