WTB 64 barracuda parts
PUSHBUTTON FISH
New Member
Rating - 0%
0   0   0
hello everyone
looking for a spare tire well and some decent gold interior pieces if someone has a nice used gas tank and some info on what tire wells will work on this cuda.
thank you jim:cheers:
the 66 tank is the same as 64,,,,67 and up will work also but the filler neck on the 67 and up is bigger then 6 6 and earlier,,, you wil need to put a hose around the filler to fill in the gap if you use a 67 and newer tank,,or cut and fit the filler tube
I have a 65 Barracuda with the gold interior that I'm parting out. The gas tank is still in it and looks good and so does the spare tire well. I can cut the well out with no problem, so if those parts will work, let me know.
I took out the spare tire and the bottom of the well has some rotted holes so it may not be any better than what you have already.
Ken
Edison, NJ
rider1454@aol.com
can you send me a pm with a price for your gas tank off the 66 or a e-mail address
thank you jim
Ken
Edison, NJ
rider1454@aol.com
íf you´re parting your Barracuda .... i was looking for the carpet-side-front-door-sill-plates ... is there a possibility that you would sell them to Germany?
Hi Timo. I would have no problem selling and shipping to you but I tried not to long ago to ship a grille to the Russian Federation and use the US Postal Service since they would be the cheapest and I couldn't. The max length that they allow is 42 inches (106.5 cm). I would need at least 47-48 inches (122 cm) to safely package the sill plates. I can certainly try to find out if we can do the shipping since even though the length may be only 6 inches too long the tube that I would use is only around 5" (12.7 cm) in diameter. So the overall combined dimensions may be fine. I will try to find out and let you know.
The sill plates look to be in really nice shape.
Ken
Ken
Ken - that sounds good - thanks a lot for looking
Hi Timo. I finally was able to get the the PO. Yes they can ship with no problem. Should be in the neighborhood of $34 depending on the total weight.
I sent you a PM.
Ken
