green1
Tie rod nuts always point up, even on a b body.
Actually mine are faceing bolt to the front of the car(laying down).his is facing rightTie rod nuts always point up, even on a b body.
please post a comparison pic of both arms. hope you got it.
Thats great ...but... I don't think it will be enuff especaily after you lower the car to proper ride hight.At best you gain 1/4".However withe the k frame welded and the torsion bar bushing replaced you may be in luck..hopefully.Sign of hope! Got my new pitman arm and it fits waaaayyy better on the sector shaft! The other one seated farther up on the sector shaft which was putting the pitman arm at a higher level this one seats lower on the sector shaft which would drop the pitman arm down and clear the tortion bar..HOPEFULLY!
A 1/4" in three places equals 3/4" and that can go along ways correcting the problem since the tie rod end and the torsion was most likely less than a 1/4" overlap.
Im placing two shims on the top two bolts of the steering box also. I ran into a little delema though..drivers side tortion bar is tweaked..bent. I have a spare 318 tortion bar im gonna put in its place for now..
I think the wreck started all this.The LCA mount and possible "mashing" the bushing bending the torsion bar and still possible a bent k frame(hopefuuly not).I had a torsion bar break on a 72 satellite just going to school at 25 mph,I'm sure it was close to breaking long before that.So to bend one you would have to have either heat at impact or a sudden impact but very hard at the right angle.I would inspect the a frame and mounts while you have the car up.Sadly I believe the PO fixed what they could and passed to rest on to you.Wow! I have never seen a bent torsion rod; snapped yes, bent, no. Could you please take a picture of it along side a straight edge?
If the torsion bar is in fact bent, check the bar mounts because they could also have been disfigured by the impact.
The frame has been welded on. It looks like it was in a front end collision because its wrinkled on the drivers side but looks like it has been fixed and straightened..
It was briefly mentioned early on.
Thanks, I missed that and I have been on this thread from the start or at least I thought I had, LOL!
You have been trying to help solve this problem since the first post and I am sure the OP is thankful for all your help. Sometimes when there are multiple posts at the same time a few slip past us. I have read through all the posts many times looking for something that may have been missed but I think you all are on the right track and will lead the OP to a successful repair.
~Michael
I will have to post a picture of that tortion bar for everyone to see. Now im not sure if the car was wrecked or what happen to it but you can tell the drivers side frame has been welded on in one spot. Yes i did look at the numbers. I actually just took a micrometer and measured my other tortion bars they were .85 and that is a 318 tortion bar if im correct. I have two 318 tortion bars and 2 slant 6 tortion bars. Do you guys think the 318 one will work for now or should i order a 340 one immediateley?
Personally I would use the two 318 torsion bars you have. That way if you still have issues you wont waste a 340 torsion bar in the process to fix the issues. What is the original torsion bar number stamped on the end and what is the 318 torsion bar stamped? I will see if I can locate the one you need on the salvage circut that would be close to you. I will be going out to the salvage yard and I can look up everything that is currently out there with nothing blocked on their computer. What we can look up doesn't contain all the parts that are out there because many companies don't release their inventory on line. Of course they are a lot of parts that aren't on the circut either.
The one i had laying around i think is a 318 one. The number with the L for left side is: 891, the other number is i think 351. The supposebly 340 torsion bar that is in my car, the number is: 892 other number is 193?? Im not sure on these theyre hard to read.
