darc1722
Just installed a new HEI procomp distributor on my 1969 318. Also installed new engine wiring harness, removed ballast resisitor (jumpered connections together) and replaced voltage regulator with new electronic regulator, that looks stock. Started right up on first try and everything looked good, but it's not charging the system. Hooked HEI (2 wires red to + black to - on coil) and used connections per the 1969 wiring diagram (except for jumpered out ballast resistor) there's also a blue wire from wiring harness to the + side of the coil as well. Any help would be appreciated, thanks.
