67 Barracuda with MRL 360
Shingar
OKC
Finally got it in the car!
[ame="https://www.youtube.com/watch?v=YlVPlDdvwf4"]1967 Barracuda Convertible with MRL 360 - YouTube[/ame]
Something doesn't sound right with that motor.
You better send it to me and I'll put it in my Dart to work out the kinks.
If not just go running around with the top down and suffer. LOL!
Oh My !! Sweet sounding and groovy looking ride right there folk's !!
Beauty! Great sounding MRL 360 you have there. 400 ponies under the hood should be lots of fun! tmm
Sounds great! Isn't it a good feeling when it's finally running... What are the specs??? What RPM is it idling at in the video?
Beautiful car. Are you going to put the A/C back in?
I kept the option to put it back in with the manifold.......not sure if I will or not.....if I do...it's in a box in my shop!
What mufflers and exhaust system is on it?
What's the duration at 0.050 and centerline of that cam?
Specs of that badass 360???
Here are the basics of what Mike at MRL Performance did on this build:
It's a mild build with excellent manners. Just what I was looking for.
360 block prepped and blueprinted for build
Stock crank, reconditioned/balanced
Aluminum heads, new valves/springs, porting, HP valve job
Stock rods, w/ARP bolts
New flat top Hyper pistons/rings
New Bearings/freeze plugs
New Roller rockers
New Hydraulic cam 228* .480" lift
New Double roller timing set w/tensioner
New Stock type center sump oil pan
New Ported Melling oil pump
New Aluminum dual plane intake
New 750 vacuum secondary carb w/electric choke
New FBO ignition system
New 8mm wires
New Champion plugs
New damper
New water pump
New flex plate
New Chrome steel valve covers w/breather & PCV
Dyno run and tuned
Those specs are very similar to the second iteration in my 68FormulaS. It was an awesome street combo.
Actually its also very similar to my current iteration. I really love mine.
May you really love yours too.
