Ok guys. I pushed my 65 Barracuda out of the garage to finish taking the body apart. But when I tried to start it, it turns over but will not start. I connected a timing light to make sure I am getting spark. It shows I am. I have just replaced the gas tank, so added fuel and have it pumped up to the filter. Carb was not showing any fuel, so I poured some gas into the carb, No start. Tried starting fluid, and no start. This is a 273 Commando that has ran great in the past. The only thing I had worked on was I had taken the dash out to restore it. I put it back in and hooked up the amp gauge and key switch. What am I missing? Motor is stock, and I haven't done anything under the hood.
Ideas are welcome.
Ideas are welcome.
