1967 Cuda FB project
I'd hate to presume you'd take suggestions from a podunk car guy like myself but if you don't mind, I'll offer some anyway.
There are a number of things that I'd like to see retained from the original interior:
I feel that keeping the stock steering wheel would help to maintain the 60s vibe. I could see incorporating a modern logo on the center cap, paddle shifters, or perhaps a modernized shift indicator added to it but I'd hate to see the entire wheel swapped out.
View attachment 1967_Plymouth_Barracuda_Fastback_Mopar_273_V8_Yellow_For_Sale_Interior_resize.jpg
72Valient4Door recently posted a picture of a dash pad he'd had an upholstery shop make for him. Although he got some negative responses when asking other's opinions (including yourself), I thought it probably looks much better when the view isn't such a close up. Then the pattern on it might not seem so pronounced. - Now, I'm not suggesting an ostrich skin pattern but I think a stitched seam line on yours would subtly add a modern detail and still retain the original contours. If the stitching theme was carried over to the rest of the upholstery it would tie together nicely.
The dashes in 1968 incorporated padding on the bottom which I think would also add a modernized touch if they had stitching that matched the rest of the interior.
I know that seating from a new car would be a step up in comfort but it might be neater to see an original pair of buckets modified to wrap around you more and given a more attractive sewn pattern. - maybe some emblems sewn in to an added set of headrests.
The 1967 dash cluster isn't ugly but it could use an upgrade.
The textures on the plastic could use some sprucing up. It's not a major change but I added a carbon fiber overlay on the top half of mine and a new silver overlay on the bottom. I suppose the colors could easily be changed to something else. If I'd invested in new gauges I think my dash would have had a more modern look.
I don't think Dakota Digital makes new gauge panels for them yet but it'd be great if they did. We bought a B-body one for our '68 Charger and I think they're great. Perhaps you could still manage to install newer gauges in the factory cluster insert. We didn't want to lose the look of the original cluster in our Charger, but we wanted better than original.
With your car being set up to handle like a track car you'd said you'd debated retaining the rear seat. The lack of necessity having one makes it easy to decide to get rid of it but then you'd be eliminating an important component that has the car appearing it came off the showroom floor.
If you go too far with the door panels you may lose some of the feel of cars this vintage. I don't know how much trouble it would be to add in modern armrests and storage pockets but it might work. - Heck, I don't think I'd rule out adding power window switches and ditching the cranks.
The B-body dash will have modern gauges in it. Still on the fence about the rear seat, in or out. I'm thinking simple interior panels, maybe brushed aluminum panels with handmade armrests with window switches in them. It WILL have power windows. (lighter than factory mech.) The seats will definitely have bolsters in them to keep my *** in the seat on heavy cornering. :D
Got a couple of the sections of the hood brace welded up. Do some more tomorrow.
Feels good to be working on my car again. :cheers:
Dam. Keep working I was just getting into it. I need to see more. This is a cool off the wall build. and I love the ideas. No time for a "sammich" you'll get fat like me.
Thanks!!! Yup, on a diet, gained some unwanted pounds stuck in a chair for 2 months!!!:protest: No sammich here!!:prayer:
Got all the braces welded up. Some ground down. Still have a bunch to grind. This gives an idea of the outcome. I think I am going to drill a bunch of lightening holes in the support structure. Hood is going on a diet. :D
This top pic shows how they made it off center from the factory.
Then I was thinking about making these work with the hood. They're off the 300 parts donor.
The 300 hinges look a little spindlely for the weight of a old car metal hood?
I'd drill lots of holes.
That style road runner scoop looks great on the barracuda body. Your definitly going the extra mile to finish it proper top and bottom. I'd buy one if you ever felt inclined to pop a fiberglass mold.
Glad to hear your back on your feet.
Any chance you're going to make the hood's scoops functional with venting?
That will all depend on how the SC setup pans out. I have cut out the center of the scoops and fitted SS mesh in the openings. So, they will allow air under the hood for sure. If the car stays NA, I would plumb to the airbox for sure. I just don't know how the layout will work for the SC yet.
Thanks for the compliment!
I am drilling holes for weight reduction. I will weigh the two hoods after weight reduction to see how much difference there is before trying to use the hinges from the 300. :D
It always seemed the logical evolution step from the factory hood on these
cars to me. Has kind of the same style just badder with extra room for a taller intake.
Can't wait to see it installed in primer.
If you do decide to go with the new hinges, are you going to fill the area where the old ones came through from the sides of the cowl?
The only drawback to "filling in" the hinge openings is that you won't have an easy way to clean out the cowl space. If the drain holes get plugged you can easily access them through the hinge openings.
treblig
Pretty Cool!! Do you think it will whistle going down the road??
Treblig
If the SC setup goes in, it will!!!
Yes. :cheers:
The top of the cowl is now closed up. No dirt can get in there. :glasses7:
I think I am going to do some hole drilling on the interior structure, etc. that you can't see or covered by panels. Maybe even some you can see. I'm on a mission. lol
The wife walked by the hood when I was drilling holes and asked me what I was doing. I said the car was going on a diet. She harrumphed me and made the comment that "it's only a little 5.7!" Like it's not gonna be fast and I'm wasting my time. The same engine in the 07 Magnum all wheel drive scoots really well for a 4800 lb car. I can visualize what this same engine will do in a car that weighs aprox 2k less than that.
It's gonna be a Hemi Cuda for crissakes.:burnout:
Maybe even a blown Hemi Cuda.:burnout::burnout::burnout:
p.s. been looking at stroker kits................................ :violent1: :banghead:
