Qa1 6 link kit?
You may want to install the swaybar link so the threaded part is pointing down, looks like it might interfere with the frame bracket, not sure.
Pretty sure the instruction call for the end links to be installed like that. They did on my Hellwig sway bar. You're supposed to cut down the extra threads if they interfere.
The instructions had them this way. Not sure if there is a reason for that or not.
