autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 9,519
- Reaction score
- 5,044
The Calvert sliders are apparently have the proper angle built in compared to the afco sliders. This is supposed to help with leaf spring geometry and help it function more as it should.
The car is painted already so if I can get by without messing with the body that would be great but trimming the fender lip a little bit doesn't bother me to much, because I did the original body work anyway so.
You mean the rear sliders to replace the shackles?
The Hotchkis leafs put the rear very low. I was not able to run their supplies dropped front hanger because it puts the rear too low. And the pinion angle was sky high. The sliders put the rear spring eye up higher. That should move the pinion up some, but put the rear of the car lower.
