Usually
The bigger the cam, the lower the cylinder pressure will be, and the less likely to detonate the engine will be. But this comes with a penalty, the softer the low-rpm take-off will be. And that leads to a higher stall TC to get off the line, and bigger gears to continue the acceleration.
To do it all requires a very careful co-ordination of parts. So if the rear gears have to stay then you sorta have to build around them. If the TC has to stay, then you really have to be careful. After that the Cylinder pressure and camshaft have to be friendly one towards the other, or it all goes sour in a hurry.
Best advice I got is to forget that 2899205. That cam scrubs pressure from a build with too much, and leaves you with a pretty small .050, yeah just try spinning tires with that in an 8/1 engine. You're not at that point,yet
For a nice torquey 340, Ima guessing a 218/222 intake duration at .050, and 9.6 Scr , will have a lotta potential. The lower your rear gear is, the higher your stall will need to be. If you need a hiway gear like 3.23s, then you might like a 2800TC. If you have 3.91s then you could probably use a stock teener TC.
With the Go-To 3.55s, the factory TC is a good starting point.
The 220ish cam is not a high rpm-powerhouse. What it is, is a low to mid rpm torque booster, just right to get a 3.23geared A-vert motoring, with the right TC. And just right for cruising 60~2400 depending on tire diameter. Its also pretty good on the 2-1 downshift at 30/35 mph. And not too bad in the Zero to 60 dash, hitting about 6200 at the top of first gear, yeah a little out of the power, but second is worse topping out at 3700.
So that if that sounds pretty good then you just have to marry the Scr to the ICA, for the gas you wanna burn and yur done.
And that's where the trouble starts.......And so; there are a few ways to skin this cat.
First.....Your engine will fall together at a certain to be determined Scr. That is to say a cheap build; no deck machining, no head shaving nor intake machining etc, Cheap. When you get that final Scr number, then you go try to find a 220ish cam with the required ICA, to keep the pressure as high as possible and yet not detonate..... that is the problem.
oh yeah sure , you can guess 10 psi low and pump up the TC and it works because you can just give it more gas and away you go........ until you run out of gas-pedal and it's too slow for you; THEN WHAT?
Well then it would have been better to guess that extra 10 psi and just either delay the power timing, or start injecting anti-detonant.
Second..... If you choose the cam first, then you engineer the Scr around a known ICA, and don't have to guess. But it usually costs more, cuz there may be machining required.
Third..... You go find somebody who has already built the combo you want and get the skinny from him
Fourth..... You call the man with all the cam experience of a lifetime and tell him what you wanna do, and he tells you, and you just go do it.
Fifth..... That guy is watching, and waiting, and ready to jump in.
Sixth..... I'm out of ideas, but there has gotto be a sixth; there's always a sixth, I just know it's gotta be here somewhere. Wyrms, help me out, wouldjah
But first you gotta make some decisions, like
what gear are you gonna run, cuz that will determine some upstream decisions. And be honest about your application;
if it's gonna be a streeter,any 340 combo will do, unless you really screw it up. So forget horsepower numbers, they are practically meaningless in this instance.
And what gas are you gonna run. This is a big deal, because each grade isabout a 5 psi cylinder pressure difference. And pressure is performance......... and economy. A 220 cam with max pressure, and a hiway gear can bring in some really good MPG numbers.
Now I just guessed at the 220*@050 cam size based on my experience. It's an all round do-everything pretty good cam.
If you want to bias for torque or economy, go down one size.
For a lil more power, go up one size.
But the rest of the package still has to be optimized for the new ICA.
And if you optimize for one size cam, it might be hard to just swap cams nexy week!, so choose wisely .
With open chamber heads and no Quench, if you optimize for mid grade gas, then you should be able to move up or down one cam size, using the gasket thickness to compensate for the pressure change.That's what I did, but I guessed low on the pressure on the initial build. That's OK, my 367 went 93 in the 1/8th on 87E10,lol
Happy Happy HotRodding
