My car keeps over heating when I’m driving
That’s the problem I don’t have any space for one.
You would with the correct style radiator.....however, Northern is a very decent brand, so I think I might do what I could to retain it. I believe once you get a good fan......or two on it, your problem will be solved.
If I am interpreting things correctly.
You have a 67 Dodge Dart with a 360.
I know the snout of the 360 aluminum water pump is linger than the cast iron of a 273, but I can not understand where your space went to.
Do you have stock motor mounts and transmission mounts and cross members?
What’s the correct style radiator for my car? When I type in 67 dart so many different ones come up.
So my car was a straight 6. I took motor mounts out of a 71 car. Not sure what the 360 engine came out of. I just know it was rebuilt.
I believe it's the 22" wide by "however" tall they are down flow. That's got tanks top and bottom instead of side to side. If you do replace it, I would go with one with two rows of 1.25 o 1.5" tubes as I said before.....but I'm not sure I'd do that quit yet. That is unless you budget allows it and that's what you want.
This is the space I have. Less than 3 1/2 from radiator to pulley.
When was the last time you drained and refilled the radiator.
Reason I ask is many times after I have refilled my rad I get an air pocket and untill it gets worked out the rad will foam over as you described.
I think I would try to deal with "what you have" since the radiator is a decent one. It's possible if you replace it, you could back up.
Some have had good luck I believe with the Ford Taurus dual fan setup. My understanding is they blow like a 20 dollar *****.
It’s been about two months.
I just can’t find a fan and shroud that will fit in that small space.
More than long enough to work out all the air.
If you were to go with a stock type rad you would want to get one like this:
Your 360 is designed to have inlet on the driver's side top and outlet on the pass side bottom.
Realistically your radiator should be fine. And your fan may or may not be sufficient at idle.
Many above have suggested things to look at before spending any more money.
Timing
Water flow
Condition of the radiator.
Coolant level.
Hoses collapsing, your bottom hose is really long so it could be colapsing.
Water pump cavatsting, or missing fins
Water pump pulley to crank pulley ratio
Thermostat opening all the way and the correct temperature.
Rad cap with the correct pressure ( type 16 lbs)
No leaks in the system ( holds 16 lbs)
First you need to determine what temperature your engine is running at with a real temp guages of some kind.
What ever you do, do not put a shroud that is flat and close to the rad. It will block air flow at speed, you might be good at idle but then give problems at speed.
Timing
Water flow
Coolant level.
Thank you! I'll start checking each thing.
@Dana67Dart shows nearly 5" from the inside of his radiator to the pulley. Do you have the same? Not to the fan, but to the radiator.
Like others, I think if you use a shroud with either an electric or mechanical fan, you should be good.
I can only fit a 3" thick fan. The fan you sent is 6". It's too thick.
Right. That's 6" at its MAX thickness, which is the back of each fan motor. It's much thinner than that most everywhere else, like right between the motors where you'd put the water pump pulley.
Please answer the question. When does it over heat? Does it over heat driving down the road? Does it over heat at a stop? Once it does over heat, does it cool back down?
These are important questions. Please answer them if you want help.
Sometimes it's like pulling teeth, isn't it?
Here’s what I got. Best pictures I could get. It’s really tight getting in there. It’s 4 1/2 thick from end of motor. The picture with the tape measuring from the inside of the engine compartment is to the center of the motor is 27 1/2. If I remember Abodybomber had the duel fans. I will have to look for his old post. God rest his soul.
