512 B build almost complete
At least as far as the BBM heads are concerned, fhe differences between the valve used in the E Street and RPM heads, from a visual perspective is...... The E Street valves have a lathe turned finish on the backside of the head, and the RPM valves are swirl polished.
Along the same lines as the differences between a Ferrea 5000 and 6000 series valve.
Left - E Street
Right - RPM
Assembled long block minus the intake. The intake porting is approx 60% complete--I also have to cut the intake .090"-.105" to accommodate the fiber gaskets x 2 plus the sheetmetal valley pan gasket-fun fun fun. J.Rob
I bought one big block Edelbrock head 4-5 years ago cheap from a guy on Moparts. One of these days I’d like to drag it out to see what I could get out of it.
After several more hours of port/divider cleanup the intake did in fact require .105" cut from both surfaces. The intake sits perfectly now with no bolt hole elongation required. I should have this on the dyno next week --mid week-looking forward to getting this one run and done. J.Rob
Impressive work! That engine looks like it is just begging for a chance to show what its got!
Well so far so good. I don't want to shoot myself in the foot but no oil leaks and I've got 3 full pulls from 3500-5500 rpm in the books. My unspoken goals rolling around in my head were 600hp/650tq and with 35 degrees timing and 180F oil 160-170F water is what you will see in the screenshot. It gives up early but I kinda figured it would with 512 cubes to feed through a more street oriented induction. I'm very hopeful a spacer combination will add some power. Considering this is going in a '70 Charger with 3.55's and a 4 spd I think it will be far nicer to drive than the previous 466 cube lowdeck. J.Rob
Beautiful build just beautiful. I like the simple fact you targeted a reliable durable street build vs trying to eek out every single possible HP. Many of us are not NASCAR drivers and just want a nice solid mill for street driving and an occasional blast or two down the strip. Well done Sir.
Thankyou, The intake on this was a bit of a wildcard but I wanted to gain him some air cleaner to hood clearance. His previous intake is a max wedge port Indy single plane and when I saw his air cleaner all I could think was how restrictive it had to be. Now he will be able to use a much more normal 3" element. I think the car will be far nicer to drive with the extra torque. J.Rob
Oh! I like that. Sweet Jess.
What cam is inside?
Which intake are you using on this motor?
What cam is inside?
I'm looking at my Comp catalog now and it has to be Xtreme Energy 23-701-9 which has a lot less lift than I remember. When I checked lift at the retainer I chalked up the sub .600" to the Howards Hyd Roller bleeding down with no oil pressure and the switch to 1.5 rockers from the 1.6 T&D's it previously had. The customer loved this camshaft in the 470 so it stayed. I don't see why he won't like it even more now that it has 41 (actually 45 since it was a 466) more cubes and higher velocity ports. J.Rob
Hydraulic lifters on a solid cam is what I see.
Yup I do it often. J.Rob
Same here. Running one in the shop truck right now. And like Kim I will run a solid lifter on a hydraulic. It's a nice camshaft tuning device.
