Stop in for a cup of coffee
Did i check in this morning? I cant remember. Still cold, still windy…
Plowed snow for a couple hours. Plow sure works better whenbits not low on hydrauluc oil (atf).
So, interesting fact- gm coolung systems retain pressure. Went to quick change coolant sensor and it was spraying coolant out. Go to top off coolant after and i destroy cap trying to remove it. Has rarely been removed i guess. It was stuck. Will see if it starts after sitting a few hours. That seems to be when there is a no start issue.
Tesla has a onboard battery heating system, that uses battery power to run.... Tesla knows full well the issues. BUT we have to start somewhere.... Fossil fuel will run out some day, if we are still on this planet...
Perhaps. But keep in mind, ALL electric car batteries use Lithium, which in itself , is not much different than fossil fuels in that it’s got a finite supply, and has to be essentially strip mined. About the only advantage of an electric car in terms of renewable energy is that you can charge the thing with a large enough solar system.
so essentially all we are doing is exchanging one problem for the next.
Gunner is gone :( My son just came and picked him up with all his gear and food. I'm sad.....:(
So we got our tests back, well finally notified, both the wife and I had the original Covid 19 Strain, not delta or Omnicron
I think that's a case where you DON'T want to be original. The base wouldn't test me, gave me a note that basically said I was "considered" positive, without testing??? Okay....wife's results still aren't back. Fortunately my work has a number to cover my time so I don't have to use time off. Crazy stuff and it's a moving target.
