Did i check in this morning? I cant remember. Still cold, still windy…
Plowed snow for a couple hours. Plow sure works better whenbits not low on hydrauluc oil (atf).
So, interesting fact- gm coolung systems retain pressure. Went to quick change coolant sensor and it was spraying coolant out. Go to top off coolant after and i destroy cap trying to remove it. Has rarely been removed i guess. It was stuck. Will see if it starts after sitting a few hours. That seems to be when there is a no start issue.
CL in Phoenix if curiosity gets the better of you
