Just Send It
There goes the neighborhood!
Gents...I am stumped and I'm looking for some help.
Here's what's going on...
1972 Scamp. The car was completely rewired using an EZ Wiring 21 kit. I retained the OEM rear harness configuration for simplicity. All of the headlights, directionals, and brake lights work as they should. But I cannot figure out the Parking Lights situation.
Right now, when I press the brake pedal the rear Parking Lights turn on with the Tail Lights. When I hit the directionals (without pushing the brake), the Parking Lights stay off and the Tail Lights will flash brightly like normal. But when I push the brake pedal, both the Brake Lights and Parking Lights turn on together.
This tells me that the Parking Lights are being fed continuous current along with the Brake wire.
There is 1 black wire at the connector that splits and feeds the both the Tail Lights and the Parking lights when the headlight switch is activated.
My diagram shows a pink power wire that comes off of the brake switch and goes into the dome light?
This is where I'm confused. If the black wires that are split power the Tail + Parking lights, how does power get to just the Brake Lights without turning the Parking Lights on? It almost feels like there is a wire missing from the diagram that feeds into the other side of the 1157 bubs. Unless I'm totally misreading the schematic.
Any help is appreciated
