DionR
I know it's come up several times before, but when I ran across an interesting article in one of the old Hot Rod magazines I snagged at the swap meet this summer, thought I would share some info.
In the January 1976 issue of Hot Rod, Dick Landy does an overdrive conversion on an older A833 box, and they show what parts need to be swapped. Looks like there are 6 pieces that are different.
Makes me wonder. If the input shaft is the same between a 3.09:1 first gear box and an OD box, then the nose of the output shaft isn't any different. So I would guess, the synchro splines are the only other difference. If so, you could perhaps keep the standard 4 speed 3rd-4th gear synchro, and then be able to keep the original output shaft. Then all you would need for the conversion is the 2nd and 3rd gears, the cluster and the input shaft (if it wasn't already a 3.09:1 first gear).
Probably not a big deal, but thought I would share in case someone was interested.
