13". I want a 14 but every style that I like one comes in 13 or 15.What diameter steering wheel did you get ?
Okay, does the 13 feel weird to you . That seems small but I'm used to my 16 or 17 in my ram lol13". I want a 14 but every style that I like one comes in 13 or 15.
I haven’t driven the car with this wheel yet but initial thoughts is I will like it as long as my manual steering isn’t too heavy. A 15” puts my arm too close to the door bar.Okay, does the 13 feel weird to you . That seems small but I'm used to my 16 or 17 in my ram lol
Damn, that's looking tough!!!Well, since the roads were too wet to do any tuning today, I decided to lower the ride height in the rear. I think it needs about 1/4" more to be perfect and since I need to correct the pinion angle now, a correction shim might get it there.
I went with the standard height split mono leafs. Dropped an inch by going from the middle hole to the upper on my inboard springs perch.What Calvert springs did you buy stock or 1" lower? Also what did did you set your pinion angle to? I've always set mine to 1* negative but when I did that with the Calvert setup I had a hellish vibration. I ended up cutting the perches off and setting it to 4* negative. Unfortunately Calvert lists the 4* negative on their website but not in their instructions.
lol, wish I could do metal work like you…. Poor Fred will gain some weight when I do the body and paint this winter.Damn, that's looking tough!!!
Show off lol
It's hard to tell what's under the paint but Fred looks like it will be pretty straightforward.lol, wish I could do metal work like you…. Poor Fred will gain some weight when I do the body and paint this winter.![]()
That's basically how mine is but I also ended using the 1" lower mono leafs. Prior to getting the Calvert setup I had SS springs with a 1 1/4" block between the spring perch and and the spring, so I knew that 1" lower would keep it basically the same height.
Do you have a stud welder? That will make some of your dents a breeze.
I may have to get one.It's hard to tell what's under the paint but Fred looks like it will be pretty straightforward.
Big time saver. Weld one on & pull the slide hammer, if you have a high spot by the dent, then pull the stud without using slide hammer and use a hammer to tap on the high spot.... simple now you're a proI
Did I mention I hate body work? lolBig time saver. Weld one on & pull the slide hammer, if you have a high spot by the dent, then pull the stud without using slide hammer and use a hammer to tap on the high spot.... simple now you're a pro
Yes, I wish I or you were closer because I'd gladly help youDid I mention I hate body work? lol
Much appreciated my friend. I might add a little weight but I’ll make sure it looks good…. lolYes, I wish I or you were closer because I'd gladly help you
That's when you just say, Eh it's a race car!Much appreciated my friend. I might add a little weight but I’ll make sure it looks good…. lol
Bill, do you really really like the steering column?Did I mention I hate body work? lol
I like it but not really really… lolBill, do you really really like the steering column?
I think I might just get kit then since it seems you had to make it work. Thanks for the review lolI like it but not really really… lol
Couple of things…. The plate at the bottom wasn’t quite big enough to cover the opening in the firewall and the column is too long in my opinion. Easy fix by adding a little sheet of aluminum to cover the gap, pulled the shaft and upper bearing and cut 4” off of the tube, reinstalled the bearing and shaft, then cut the shaft to length, welded on the coupler and now it’s perfect.
If I wasn’t lazy, I could have made my own but for the price, it isn’t a bad option.
Lol, thanks. did you snag that one from your witch neighbor?I have an extra broomstick if you want to copy mine. Lol
