my buddy dave called and asked if it was ok to install the crank. while I'd have liked to have done it i know he is into the build and its taking up room in his garage. crank is in and he says everything looks great. 2 thousands clearance on the mains he says.
steering box and shocks showed up today jamie said. thanks @GMachineDartGT for getting the stuff to me so fast, can't wait to get home and check that box out. dave has a 360 built sitting on a duster kframe that he asked if he could see if the new box will fit with the headers and all. if it fits he may buy one instead of going manual steering. I'll take that over monday and maybe we will mess with that some too
What's your rod bearing clearance? With that clearance you can run a 30 grade oil. Maybe a 20 but you do have all the leaks around the lifters and rockers so probably a 30.
