Camshafts and Compression
They work on time, above 3,000 rpm they don't have time to bleed down.
Or run the compression that will work with rhoads lifters and or run more cam.
To me they seem like a good idea, instead of running a medium sized cam as a compromise between power and street manners, run the bigger cam instead. eg. a 245-255 instead of 230-244.
Rhoads lifters flat out work, in fact IMO if you're using a hydraulic camshaft for street or strip that's what to use.
6500 rpm is a breeze with the right spring.
If that fails, I'd just stick a solid lifter on a hydraulic shaft. lol BTDT
PS if the valvetrain doesn't sound like a sewing machine at idle they aren't set right
Agreed, if you could keep the benefits of a large cam for power and gain back some street manners don't really see the down side. Saves you from making a compromised choice or at least a lesser one.
The only 'problem' with Rhoads lifters is the perception that they will restore duration & lift as rpm increases because the lifters have less time to bleed down. The problem is that the groove down the side of the inner piston that promotes low speed bleed down....is still there bleeding down the lifter at higher rpms. Depending on many variables such as internal lifter clearances, oil viscosity, spring pressure, rocker ratio etc, the full lift & duration might NEVER be restored. With some combos, this might be a HP benefit, others a HP loss.
With the V-Max, that's not entirely true, as they can be adjusted to work like a standard hydraulic lifter.
What Valman is saying is that spring pressure alone might not be enough to collapse the lifter. What else can be done?
Exactly. Even though it has double springs, still doesn’t collapse the lifter. Cranking down on the rocker adjuster WILL strip the thread. Ended up pulling the intake off and the rocker shafts
Pic of the disassembled v-max lifter. Pretty simple design.
Bled off all the lifters, reinstalled, set them up for 0.012’’. Should tighten up to about 0.010’’ when hot. 0.010’’ is minimum.
This should give 7-8 degrees reduction in duration, and drop the same 0.012’’ off the valve lift.
Did a few calc’s, if all goes well, I should be back to around 185-190psi cranking pressure.
Very possible, but after taking these apart the clearance between the shell and inner piston is really close. The oil seal was tight pulling the piston out, even with the groove.
Different situation in a running engine of course, but they seem to hold their position.
I couldn’t bleed them assembled by hand, I wasn’t game to squeeze them in the vice..
Yeah, it doesn’t look great after the lifter adjustment. I haven’t measured yet, looks like they could be 1/4’’ longer.
I think you should call Rhoads and get their opinion. With that many threads showing, it appears the lifters are staying collapsed some. If that's the case, and you adjust the rockers with the lifters collapsed, when they pump up, bad things are gonna happen.
The lifter has to be bottomed out initially to make the adjustment with the feeler gauge under the roller.
Then open the valve slightly with the adjuster. Back off until the feeler gauge slides. The install notes say that the lifter should be down in the shell after the adjustment.
If this pic is showing where the adjuster screws were(right), to where they are with the correct lifter preload(left), then they were waaay off.
That change should result in a noticeable difference in running duration, and will probably show up on a cranking pressure test too.
I doubt that pic shows a before and after between those two rockers. Likely one is adjusted (left) and one is not yet adjusted (right).
I know exactly how they work. I recommended you call Rhoads to get their opinion. Carry on sir and good luck.
