273 commando Build
thanks ! unfortunately I spent too much time with you tube already I give up ! I clicked on a bunch on things to make it open to public with no good results
Can you view it on your channel?
yes it plays when I click on it... why can't I just copy my brower when it is playing and drop it here?
What is your You Tube channel? Let me give it a try. Just give me a link if you can.
Here you go.
do one or the other >>>
spin spline hold engine
hold engine spin spline.
the mistake I made was I pulled shifter out gear and into neutral before i attempted to install the engine . I should have left it in gear and with a little wiggle it should have went in perfect. . live and learn
update ... update ...
I put on at least 500 miles on the rebuild and just did a oil change and filter .. no silver at all in the oil on my 273 build and it is running Great ! NO LEAKS NO ERROS ALL HOME RUNS ! .. this 273 is making way more hp and torque now after the fresh rebuild and port and polished heads this time around . and will probally make even more after is loosens up some . very very happy ! the 273's rock !
You changed the block to a new one - what pistons are you running and bore size - thanks.....
Yes , oem low mile commando block, I used all my rotating parts in the new engine .. original stock bore... stock 3.625 commando pistons ...
Thanks.....have someone looking for 30 over pistons as that how his Commando motor came - flat tops pistons as well.
I've got some good used +.030" high compression Commando pistons and rods if you are looking for them
Thanks....I'll let him know there is some usesd ones available. I have a set of standard ones from my motor I need to list as well.
Send that information through a PM. We don't want to turn the thread into a swap meet and get it taken down.
Hello Stroker402,
Am I understanding what you built correctly. A 1966 273 commando engine with 273 heads. Using OEM Chrysler head gaskets? What is the part number exactly? So I can look this up.
Am I correct you never found an exact match to the oddly shaped oem gasket you found installed?
Please sir.
Tony H.
Hello Stroker402,
Please sir.
Tony H.
the original style steel shim gaskets are not reproduced any longer.. I used some factory mopar 318 composite gaskets. I don't have the number in front of me .. there are pics somewhere on my post . other people have posted the steel shim gasket part number there also.
Sounds good! We're putting together a '67 273 Commando for my '66 Valiant Signet. Can't wait 'til it's done. Going to be referring to this thread many times, I'm sure. :)
