ddart cart
I should be outside doing this aleady.
74 Dart. 318 needs out. 360 needs in. 904 stays in. Temu hoist is scary. I can nose the Dart into the garage, getting the front wheels on cement. Beyond the garage door is dirt, so rear wheels on soil. The higher the hoist goes, the more it wants to twist, but I did stiffen it up since last use.
Will the trans be okay left mounted in the car?
Should I use ramps?
Just use a floor jack under the K?
Can I survive without a leveler?
Should I torque the hedman shorty’s first?
Will my 904 actually bolt up just by enlarging one hole on the flex plate?
What did I miss?
I never did this so I’m looking for clarification of procedure.
Thank you in advance,
-Doug
Should I use ramps?
What did I miss?
-Doug
