Figured id share my garbage..
I’ve dynoed that Team G manifold, it has the poorest fuel distribution of all the manifold’s I’ve tested for the 440 plus it was down 80 hp from the original mopar M1.
Did you ever install the custom cam you mentioned in the first post? Specs? Also, what fuel are you running?
Only 7-8psi?!
Any chance you remember specifics on lean/rich cylinders?
It’s gonna be a good day.
Only 7-8psi?!
Never did, ended up selling it.
It’s on E85, just starting out around 7 and see what it makes then go from there.
Only 7-8psi?!
I mean, you gotta start somewhere right? Wastegate spring seems to be the correct place to do that. Does anyone ever leave it there though?
Sorry I don’t it’s been ten years but it’s a pos of a manifold. Like I said before tq and hp was far below another old manifold that had power curves that made no sense. I tested all manifolds with the same carburetor on the same engine about forty five minutes apart. The team G in my opinion isn’t worth a set of gaskets to install it it’s just scrap aluminum.
Good to have a variety of tunes per boost levels. Have a good street one then a track one.
Yea I don’t envy the amount of chassis tuning I see in your future.
When the big number flashed on the screen all of our faces went blank, Until we saw the boost number. Then it made some sense. We definitely had no control of the turbo. We pulled the wastegate and hillbillly rebuilt it and then were able to control the boost quite a bit better. Crazy thing is Chris’ engine is making 26hp per pound boost with my dumb dumb math, at the 14 psi level. That’s a number to be happy with. @Turbo440Dart you no longer can call your garbage, garbage.
What is the rear suspension? That thing is making massive power and torque BELOW 5000rpms. It’s goin to absolutely boil those rear tires.
Split monos, sliders, Viking DA’s and assassin bars. The car isn’t mini tubbed and the springs are not moved so it’s riding on 255 ET street Rs. It’s a handful on the street to say the least
700hp on a freaking 255 is going to be like a baby deer trying to walk the first time on a frozen lake.
:rofl:
