Oldiron440
Big blocks rule small blocks drool!
I’ve dynoed that Team G manifold, it has the poorest fuel distribution of all the manifold’s I’ve tested for the 440 plus it was down 80 hp from the original mopar M1.
Any chance you remember specifics on lean/rich cylinders?I’ve dynoed that Team G manifold, it has the poorest fuel distribution of all the manifold’s I’ve tested for the 440 plus it was down 80 hp from the original mopar M1.
Did you ever install the custom cam you mentioned in the first post? Specs? Also, what fuel are you running?
Only 7-8psi?!
Only 7-8psi?!
I mean, you gotta start somewhere right? Wastegate spring seems to be the correct place to do that. Does anyone ever leave it there though?Never did, ended up selling it.
It’s on E85, just starting out around 7 and see what it makes then go from there.
Sorry I don’t it’s been ten years but it’s a pos of a manifold. Like I said before tq and hp was far below another old manifold that had power curves that made no sense. I tested all manifolds with the same carburetor on the same engine about forty five minutes apart. The team G in my opinion isn’t worth a set of gaskets to install it it’s just scrap aluminum.Any chance you remember specifics on lean/rich cylinders?
I should have known better to guess higher lol very niceHad a MASSIVE boost creep issue and the first pull….well I’ll let the graph speak for that.
Atta boy!!!Has me thinking turbo now
Those numbers show closer to 31hp/pound. Even better.That was on 14psi. Did 559/666 on 7psi.
Left it on 10 and it made 653/768
What is the rear suspension? That thing is making massive power and torque BELOW 5000rpms. It’s goin to absolutely boil those rear tires.
The numbers are posted above. But here’s one I took a pic ofUpdates? Dyno sheets?
