Amp meter pegged
diymirage
HP@idle > hondaHP@redline
michigan
71 duster, came with a slant six but now has a junkyard 360 in it
When I dropped the 360 in it almost a decade ago in probably put a new alternator in there
A few days ago while driving my radio cut out and my oil pressure gauge went dead
I've since notice when this happens the amp meter also pegs past +40
At Idlw it sits close to dead center but as soon as it gets a few rpms on her the amps shoot way up...what's going on here ?
First, disconnect the regulator and see if it stops. Next check and be CERTAIN that the VR is actually grounded. Don't just look at it. Clean the firewall behind it, around the screw holes, and clean the VR around the screw holes. Use star lock washers. If the charging stopped when you unplugged the VR, and if cleaning the mounting does not help, then replace the VR
If the charge does NOT stop with the VR unplugged, either the green wire from the VR to the alternator is shorted, or the brush holder connected to the green wire is shorted to the alternator case. In rare cases, the rotor winding itself becomes grounded.
DO NOT DRIVE it in this condition. Unless you unplug the VR and drive it with no charge
I won't even own an A body that hasn't had the ammeter bypassed. I don't trust em.
Get a thermal camera, stat.
Ok, so this is what I found
1, with the VR disconnect the amp meter sits stoic
2, with the VR connected and an extra ground wire ran to the hot side of the battery the amp meter will sit stoic as well, but the engine will keep running with the ignition off
3, I'm an idiot
4, with the VR connected and an extra ground wire ran to the negative side of the battery, the amp meter will show just past center at idle and between the 1st and 2nd white mark past the middle when revving
Not showing anything crazy at that point
I haven't had a chance to drive it yet but I think the ground issue was a likely culprit , so I went ahead and cleaned everything and reinstalled it
Ill report back once I get some miles on her again
I prolly should but I don't like the idea of a 'dead' gauge
What would the camera tell me ?
3, I'm an idiot
It sure sounds like it became ungrounded.....a common issue over time. The thermal camera is a really good idea. It will show you where heat buildup is.
3, I'm an idiot
It will show any hot spots in any wire, and it will show you any circuits that are running, overloaded, etc.
I have used them to find key-off draws, before. Plus overloaded breakers, and poor junctions in home wiring.
I have one on my phone, it's a handy thing to have. This is my bathroom fan, you can see the GFCI outlet (which draw power all the time, even when nothing is plugged in). The cord is not showing any heat because I just turned it on, but over time it will warm up, too. It's not drawing much power so it takes awhile.
The ammeter is showing something is wrong. It was cheaper for Chrysler to install than a thermal camera.
There's only a handful of reasons why a battery would draw that much current, especially in the circumstances described.
I bought a thermal camera off Amazon. It is really amazing for trouble shooting things. You can easily find bad electrical connections and stuff like air leaks in your house.
Here is the link to explanation and instructions. My neighbor had his wiring melt down and burn in a 74 Duster because of the amp gauge wiring.
I'm prob on your ignore list but hate to see you destroy your car.
It should show discharge. If not something is wired wrong.
Connecting ground to the hot side of the battery is good way to create heat, lots of it.
The whole reason for a fusible link in the battery feed is to prevent the battery positive from grounding.
3, I'm an idiot
LOL. But no reason you have to be ignorant about how this works. Lots of posts on how the charging system works
So problem appears to still be there.
Do you have voltmeter? Clip the red lead to the battery positive and the black lead to a battery ground.
Rev the engine slowly while watching the voltmeter. If the amps to the battery go up with increasing voltage, then the problem is lack of regulation. Three possibilities then: 1. The alternator brush or green field wire is grounding. 2. Regulator has failed. 3. regulator is getting wrong information (reading low voltage or no voltage on its sense terminal).
Why the battery draws more charge with increasing voltage just discussed last night here
How the regulator works
Identifying Chrysler Alternators (1960-1976)
Post #7 has the links to MadElectrical
so, since were discussing amp meter bypasses, i seen one guy on youtube who simply ran a heavy gauge wire from the charge stud on the alternator straight to the battery (i guess this counts as one of the "big three" of general automotive electrical upgrades)
he left the amp meter in place and wired up as usual, claiming it is now no longer carrying all the current, since current takes the path of least resistance and simply travel through the larger wire straight to the battery, does this make sense?
You'll do what you want of course, but there's a video in the link which explains the drawbacks to the bypasses and shunts.
(apologies for the link format, some sort of software glitch @Joeychgo is aware of.)
what glitch? All looks good to me? PM me please
Some of these links we post, and copied right out of the address box, get renamed to some silly thing like "pardon our intrusion" or some similar
Instead of the link showing as URL or snippet, it shows the entire post. I find it very hard to read the person's post when there are one or more posts showing within it.
My view is that the reason for supplying a link is a reference for those who want to go read more.
In contrast to incorporate something in to a post, thats what cutting and pasting is for.
Just my perspective as a user.
I mentioned it in the website thread so figured you were aware of this new quirk.
