yellow rose
Overnight Sensation
Heard that a lot, have you ?![]()
Many, many times. Mostly from my wife.
thanks. I had already gone over most of the numbers. Had no intentions of using 2.76's or stock converter. My stock 360 with stock converter and 2.94's cut's consistent mid 1.8's in a 3200 lbs Duster (without driver), so yes, I'm planning on a much better 60 ft with a lot more motor, gear, and converterQuestion here is how much of a street car does this need to be?........2.76's>3.55's>4.10's?....converter, 2500>3000>4000stall?.
Doing just a few calcs here to give you some idea of what your looking at, these are the on track hp no's you'll need for 10.90's@122>
@3000lbs all in= 450 on track hp with a 1.52 60ft.....(low comp 400 with good heads etc. poss)
@3300lbs all in= 495>>>>>>>> 1.52 60....440
@3500lbs all in= 525>>>>>>>> 1.52 60....440
If you don't have a set up that can 60ft near those no's because of the street limitations you impose on yourself (gear/stall) you can add to those hp no's, or loose anywhere from .3>.5 or more sec's in ET. I know your not into any of this stuff 318, however these are reasonably accurate no's to follow, and will give you an idea of how much power you will need to make and the 60 needed and therefore help in choosing the parts needed, we all know the combo's needed to make these numbers so shouldn't be too hard. You probably know all this but perhaps it may have some use and it is more or less something that is set in stone as it were of what will be needed for you to achieve your goal with whatever you end up with for a car, motor and the chassis set up. You may not like what you see or agree but it is what it is as an NA only set up.
Depends upon where your mind is , I guess .I'm glad to know what GFY actually means! I always thought it was Go F@#% Yourself!
Cley
Glad you cleared that up. Where I come from...that has a totally different meaning.
Just about anything yellow rose says gets you giddy doesn't it..lol..
..Cabin fever, you can only watch so much Live PD or sit around the coffee shop bs'n with the guys before you have to buy something.....12 pages on a car and motor that doesn't exist......
Boight what??.. aluminum heads two months ago LOL...Cabin fever, you can only watch so much Live PD or sit around the coffee shop bs'n with the guys before you have to buy something.....![]()
I ment why I was commenting, one thing I do get a kick out of threads like this is when guys say it takes this much power to go this fast at this weight etc...some how I've never had it that easy. Get the Moroso speed power calculator out and the car "should " be going this fast and its struggling to run what it does. Theres only been a few times in thirty years that I've found fifty hp solutions, maybe its because you apply what you learned last time to the next time before there is a problem.Boight what??.. aluminum heads two months ago LOL...
My experience is that when the numbers don’t work out, it falls into one of these catagories.......
-the dyno numbers are happy, or if the motor wasn’t dynoed, it doesn’t make what it was “supposed to” make
-actual track weather conditions are way way below “standard” conditions
-the “car” has issues
Usually....... it ends up being a combination of all 3.
My friends Stocker will beat the Moroso chart even in the middle of summer.
It just takes someone willing to keep tweaking the combo...... which means buying and testing a bunch of parts........ most of which will end up not working.
Most bracket guys bolt it all together....... and then iiwii.
Can't be worse than what, 10 pages on how to hook up a tach ?? LOL12 pages on a car and motor that doesn't exist......
I just look to share the experiencemmmm...I must admit he does have a knack of generating posts on a thread..perhaps I should post up a "what it will it run thread" on a totally new BB combo that we are going to be running this year BUT with all details....prob won't get anywhere near the replies![]()
or a tach 2 years ago..... LOLBoight what??.. aluminum heads two months ago LOL...
Isn't this what makes it fun? I mean, I could just buy a 575 hp crate engine and take the fun right out of it.Big heads with big valves on top of low compression with small cubes?
A stock 400 with 75cc heads and .040 gaskets works out to 8.4:1cr(8.8:1 with a .020 steel shim gasket).
Doesn’t sound like a winning formula to me....... but it’s not my money.
It’ll require more gear and more stall, and be less forgiving on cam selection.
The challenge of building a 10 second car with no money soulds cool, makes me wonder how close I could get.
I've never dyno'd an engine. Never will. ET slip works for me. Only calculator I use is the 1320 divided by my MPH to let me know how well the car works. I mean, all the gurus said my stock 360 Duster with 2.45's, stock manifolds, stock converter was a 15 second car. It went 13.9s. I added 2.94's and headers and it goes 13.3's consistently. Yep, same as a factory 440 6 pack car with 4.10 Dana. Hmmm.My experience is that when the numbers don’t work out, it falls into one of these catagories.......
yes, street cars are not nearly as easy as a dedicated bracket carI think guys get into trouble as soon as the first compromise is made fro money or street etc.. The cars just not going to run up to its potential.
great post!^^^^^^ It all started decades ago when people substituted hotrodding for $$$, now so many substitute $$$$$ instead of using hotrodding. But speed costs money, who can go the fastest for the least $$$$$ !!!??????????????????????///////////////
Divide the amount of fun into the number of $$$$ spent and the answer is!????????????????////
