racerjoe
Here's the cluster in the dash. As you can see it is now centered over the column. I added a couple inches to the left side and took out the same amount on the right to accomplish this. You may also notice the radio and A/C control holes are now filled as well as where the dash pad used to reside. Eventually the A/C control will go where the the radio used to be.
