Jul 14, 2014 #76 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Thanks sleepyhead. I finished welding in the tunnel yesterday . Today I will seam seal and top coat it with black. Attachments image.jpg image.jpg 30.3 KB · Views: 267
Jul 14, 2014 #77 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Ready for black epoxy primer. Attachments image.jpg image.jpg 38.1 KB · Views: 254
Jul 14, 2014 #78 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Primed Attachments image.jpg image.jpg 46.2 KB · Views: 247
Jul 14, 2014 #79 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Next seam sealer Attachments image.jpg image.jpg 42.1 KB · Views: 249
Jul 14, 2014 #80 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Damn, I still need to locate front mount for center console Attachments image.jpg image.jpg 46.9 KB · Views: 248
Aug 2, 2014 #81 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York I finely got the consol fit. Fits prity well . Next I will install trany and modify clutch peddle for Tillman hydrolic clutch master. Attachments image.jpg image.jpg 39.5 KB · Views: 233
Aug 2, 2014 #82 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Cut brackets shorter. Left room for carpet and sound pad. Attachments image.jpg image.jpg 37 KB · Views: 240
Aug 2, 2014 #83 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Removing clutch spring return mount Attachments image.jpg image.jpg 44.6 KB · Views: 244
Aug 2, 2014 #84 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York I mounted the pedal assembly and used a paper templet to determine bracket location For clutch master . Attachments image.jpg image.jpg 36.3 KB · Views: 218
Aug 2, 2014 #85 340sFastback Well-Known Member Joined Mar 25, 2007 Messages 5,642 Reaction score 3,972 Location Maryland That tunnel looks great! Will shifter be centered in console top plate?
Aug 2, 2014 #86 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Bracket now welded to pedal assembly Attachments image.jpg image.jpg 47.8 KB · Views: 212
Aug 2, 2014 #87 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York The best spot for bracket places the hole for master Right over the rib in firewall .im going to flatten Out the rib. Attachments image.jpg image.jpg 33.6 KB · Views: 242
Aug 2, 2014 #88 4spdragtop Well-Known Member Joined Aug 28, 2009 Messages 44,354 Reaction score 28,975 Location Ontario Parts Unknown Phenomenal work! Just read your entire thread. For color, I would go with gunmetal grey with a little flake, and then maybe some ghost stripes??
Aug 2, 2014 #89 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Sliced rib to one side of hole position . To relive the area for re shaping with a torch Attachments image.jpg image.jpg 37.9 KB · Views: 231
Aug 2, 2014 #90 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Hot!!!!! Attachments image.jpg image.jpg 40.1 KB · Views: 247
Aug 2, 2014 #91 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York The pedal assembly is bolted to help support The area being heated and flattened Attachments image.jpg image.jpg 46.2 KB · Views: 233
Aug 2, 2014 #92 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Clamps helped hold new bracket from moving While heating and hammering area. You can see The area heated by the burned paint. Attachments image.jpg image.jpg 39.4 KB · Views: 220
Aug 2, 2014 #93 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Wire brushed. Welded up slit . Ground down And brushed. Fit checked and heated again And finished shaping . Attachments image.jpg image.jpg 38 KB · Views: 206
Aug 2, 2014 #94 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Cleaning up inside. After cutting holes for master Attachments image.jpg image.jpg 29.6 KB · Views: 216
Aug 2, 2014 #95 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Sanded and scuffed area for prime and paint. The primer shows how flat the area had become Attachments image.jpg image.jpg 25.1 KB · Views: 218
Aug 2, 2014 #96 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Inside Attachments image.jpg image.jpg 29.5 KB · Views: 213
Aug 2, 2014 #97 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Ready for install Attachments image.jpg image.jpg 42 KB · Views: 221
Aug 2, 2014 #98 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Made gasket out of packing material Attachments image.jpg image.jpg 39.7 KB · Views: 220
Aug 2, 2014 #99 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York With reservoir on Attachments image.jpg image.jpg 42.2 KB · Views: 216
Aug 2, 2014 #100 kbsouers Well-Known Member Joined Dec 4, 2012 Messages 203 Reaction score 3 Location Fishkill, New York Side Attachments image.jpg image.jpg 47.6 KB · Views: 201
