Rear axle finally finished and back in.
Thanks!! Man, this is slow work!!! I never would have made it past my first shift on the assembly line!!!Very nice work.
No clothes on the line today. Whiteoutso either 'a' no washing got done that day or 'b' after you were done you got brownie points for getting the wife new clothes pegs![]()
ooh! that's not nice.No clothes on the line today. WhiteoutView attachment 1715887121
Hopefully AMD will refund / credit for incorrect items. You should send them pictures you posted here and "maybe" they'll actually re-produce an accurate part. Bummer, at least you were able to locate a good used one.This “authentic” repro starter splash shield says it fits 67-72 A-Bodies - NOT!
The upper one is for A bodies and not reproduced. I’ve been able to find a couple of good used ones.
Why clothes pins? When applied as directed the 3M weatherstrip adhesive is instant…maybe one or two in a tight turn but that many ??. Apply to both surfaces lightly…allow to dry to semi tacky then attach….I used it incorrectly for years till I read the directions….
Jim, my cuda was factory undercoated and the gas tank was completely undercoated as well. Same thing with my 66 Charger. Just an observation.
Beautiful work that you are doing there, regarding the third member paint daubs, would you happen to know what color would designate a 3.55 gear ratio? and what about the rear spring paint daubs, can you explain those also? keep up the beautiful work and thanks for sharing..Rich
