1969 Race Dart w/ 426 Hemi- garaged for 45+ years
Is that all spring holding the rear that high? thing would look great with like 4" out of the back :)
Dropped the fuel tank this morning, no big issues other than a stubborn tank bracket bolt and I had to cut off an air shock fitting bolt. The dual fuel pumps have hard lines, so I disconnected them from both the tank and the pumps to make it easier.
At least your FIL knew that air-shocks were not the best shock for the car and made his own brackets AND left the OG brackets there. Now you can use the OG placement. Man I'm loving this thread!!!!
Thanks! Yes, I am going back to using the original location for the new shock :thumbsup:
Just put the largest 15" tires that fit without rubbing and set the ride height accordingly. If you look at some of the old pics from that era that is the way the cars were set up.
The wheelwells have been raised and flared. Start at post 141 and read forward and you will see the wheelwels in primer and the flares.
I know they have been made larger, that's normal on most darts with large wheels.... look at the roof and the lines of the car... have fun not sliding down the seat while driving :)
BTW.. i'm not picking on the car at all... i just think they look better with the rear down and the tires tucked a bit :)
