FomocoReformed
Got the axle back from the shop! They put quite a bit of weld on it, should do the job I think. Still need to weld the axle tubes, cut the sway bar brackets and perches, and get new perches on it. The shop was nice and pulled the old wheel bearings for me, which is good since I don't have a slide hammer.
This center housing is still the most disturbingly rusted thing I've ever seen, guy at the shop said the metal is plenty thick so it's not an issue. :blob:
Also my motor mounts came in. :burnout:
