needsaresto
- Joined
- Nov 13, 2004
- Messages
- 7,626
- Reaction score
- 287
Thanks for that info! I am interested in going with a rack and pinion eventually. For now I'll stick with my manual gear box;It fit's my budget!!
The brake kit is here!!! WOOO HOOOO
Time to mock up a 245 front tire.
We've done it! ECI has developed a Mustang II/ Pinto BIG BRAKE KIT that's perfect for your street rod.
By combining components from existing kits, we can now offer 11" diameter rotors, BIG GM calipers and our aluminum hubs.
This kit provides 65% more braking with no wheel offset! No other "Big Brake Kit" can offer this at any price!
The mustang wheels im looking at only come in 17x9 or 18x9 for the fronts and that's more then wide enough.
A 275 will fit and look more appropriate IMO. 245s are stretched on a 9 wide.
Did you put that FR500 on your Dart?
Thats the wheel I was going to try to fit on my Dart. I'd have to hog out the hub area so the mustang II dust cap will fit through it. The 9" wide wheel will limit my turning radius quite a bit and i'll have to do some massaging of the inner fender for a little more clearance. At this point its looking to be more work then its worth.
Back to the drawing board to find wheels in 17x8 for the front and 17x10 or larger for the rear.
Looking for wheels is a big PITA. I'm finding 17x8's all over the place, but can't find a matching wheel in 17x10 or larger.
Anyone have some wheel ideas for me?
That green masking tape looks suspiciously familiar.I got the inside scoop and talked this barely used setup from a certain someone on here.
Does the Alter K increase turning radius over stock? I have AR Shelby Redline wheels 18x9 6.5bs on mine. 6.125-6.25 would've been PERFECT but oh well. I have zero issues turning whatsoever. Does the Alter K increase track width over stock? I've had several people ask me "how the hell did you fit those on the front?" My answer is always "I bolted them on". I have pics somewhere of the frame rails steering lock to lock and the worst spot has 3/8" but the tire would be pulled away while driving though.
Its not an alterkation, its a Hemi Denny k. And with the rack it sure seems like i get a heck of alot more turning radius.
...... thing that I didnt consider when fitting and buying damn wheels was factoring in negative camber. I currently run .75 negative and if I do happen to have a little fender lip contact at the top I can go to 1 degree negative and problem solved. Most of the Pro Touring guys run 1.5 degrees negative and say tire wear is fine.
I don't quite understand why you want to push so hard for that last bit of frontif you can fit a 9 wide wheel, go for the 275 tire you wont be disappointed.
everytime I think I got em happy.....they add another 1"
please educate me...why so much negative camber for the street....I can only assume for better (?) cornering
That is kinda my point if a guy can fit the 9 wide wheel by all means run a 275. If a 245 is all you want to run, use an 8 wide wheel. This a "Pro Touring" build and so to heck with pizza cutters put some meat under there!I don't quite understand why you want to push so hard for that last bit of front
tire width.
Wouldn't a 245 tire on say, an 8" rim, turn in a lot easier and with no spacing issues.
It seams like the farther in you can pull the outer edge of the wheel/tire, the lower
the car will look.
