71DusterSwe
Wow, almost a year has passed and not much has happened.
I could use some advice on where to Connect the vacuum lines to finish this, where do I put like the hose for the brake booster, distributor? I am also going to run closed crank vent but I don't know where to put the hose from the valve cover?
We also ran into a problem with using the old linkage from the slant six, all gears work except putting it into first, it's so stubborn that it pulls the upper arm out of the bushing.
Other than that the only big thing left is to make some throttle linkage, I tried searching in some Swedish Stores but couldn't find any "complete" sets.
Now I just hope for better weather, last morning I had -33 Celsius...
Cheers
Cheers
