1973 Duster with make over
I painted the rest of the body parts this last weekend.
Just so I am clear, when you changed directions and went back to the stock firewall I am guessing that means you also dumped the idea of using the Ram Heat/AC box. Correct?
I've been saving one of those boxes to do something similar, but with the hope that I can re-route the AC and heater hose connections out the stock holes so I don't have to cut my firewall. My biggest concern is how close the box gets to the throttle pedal. There are at least 2 other builds here that have use the Ram box, but so far no pictures of how it all interfaces at that location.
Sweet car, keep it up!
Yes sir, I dumped the ram airbox. I don't recommend using one on a stock firewall if your after aesthetics. I have a factory a/c box and wiring, but I couldn't find a replacement a/c firewall. I ended up installing a non a/c firewall. I plan to purchase the Classic Auto Air kit. I will create an adapter that goes from the factory ram a/c compressor to the new lines.
I started mocking up the exhaust today, but I needed to stop until i acquire some hangers. I decided to ditch the 3 bolt header flanges and use V-bands. I am putting the mufflers at the rear, most likely using borla xs mufflers. I also installed a cheapie ebay radiator. I finished up the rear brakes lines last night.
Well i got the car started up today. It runs great. I have to bleed the brakes, adjust the rear suspension, and loom the harness wires. then it gets a low speed test drive in parking lot. I was able to modify the stock /6 auto shift linkage to fit the 46rh. I also included photos of the od and lockup sensor being fed fluid by a braided line.
I brought the duster out to my parking lot and did a nice little burnout. It didn't instantly break, so that is a good sign. Now it’s time to wet sand and add more clear for a deap shine.
Well the duster took a step back and then back forward. Turns out the single paint didn't catalyze properly. I took off the paint, re-primed, and finish sanded it. Then dropped it off at a guys shop for the base and clear. I just didn't have time to redo the paint myself. I restarted the final assembly and this is where I am at now.
Great looking build. What size fuel cell is that? I like how you recessed it into the floor. Do you have any photos of how it's mounted by chance?
the 'new' new paint looks great, much more depth of shine. :thumbsup:
ant reson you mounted the rear coilovers so close together? it's normally best to get them as far apart as possible to help reduce body roll.
neil.
I don’t remember the exact size, but it was a cheap Summit or Jegs one. I removed the bottom bungs. There is a frame that holds a 16g box I weldup. The tank sits in the box on a rubber mat and I have straps that go over the top of the tank.
neil.
I’m certain wider is better, but I built the suspension almost 13 years ago. In the testing I had done body roll isn’t noticeable. Definitely better than all the stock A bodies I have owned. I can easily widen the shock mounts or add a anti-roll bar if it ever becomes and issue.
