273 parts interchange
was thinking of taking left over parts from my 340 build and some aftermarket parts and building this 273
was thinking if 273 was a shorter stoke might beable to use pistons or ?
really bought it cause i have most of the parts i need but bolts to build my stock 340
easier to strip this engine then trying to hunt down the right bolts
if i was to build it wouldn't care if had the "right" v/c bolt
tore it down today too much rust .and would take too much $$$ to build ...so unless someone needs some parts off it ..its going to scrap yard
I believe that you can swap rotating parts (cam, crank & rods) between 273/318/340, the 360 is all different, only the heads interchange.
