Without Mini Tubbing, will I be able to fit 275-60 tires under my Valiant knowing that I will have to move the springs in to the subframe rails?
Apologies for the Hi-jack.........
Bob
you will have to move the springs an mini tub it before you can fit anything bigger than a 255 under it,
jayson, how wide is your rear end? im running a 275 60 15 with a 15x10 wheel with 5in back spacing, it doesnt rub but its close. i moved my wheel tubs flush with the frame and my springs centered in the fram rail, how wide of a tire will it fit without rubbing (car will not be street drivin
i run a 325 50 15 on a 70 duster with superstock springs springs are relocated 1 inch in and not sure of back space but will find out i have no issues running these i will get some pics as soom as i find out how
