318 gone crazy
ramrod340x
Cambridge Ohio
I have a 318 .60, KB 399 pistons 360 heads that are 1.60/2.02 with 65cc combustion chambers at 11.3 to 1. H beam rods seel crank. I want to know the best Intake, cam and carb to put on this. I was useing a air gap intake race demond 650 and A mopar 509 292 hydo cam. its in a 71 scamp and ran 8.15 in the 8th with a 4000 stall and cheata valve body with 4.86 gears on a 26x8 M/T slick
At 11:1 compression with that gear, I'd reccomend the Mopar .557 solid, Mopar M1 single plane and the 750 Mighty Demon carb. Just my 2 cents...
run as much cam as your heads can flow, and I'm with DusterKrazy on the carb and intake.
