bongy337
Just a guy who loves old mopars.
Hello Mopar family, Could anyone let me know if this combo can make good horsepower. If so, how much?
4448308 cylinder head Sourced from 1988 Dodge Truck 1.88 intake /1.60 exhaust
3512100 Cast Iron Intake Manifold Sourced from1972 340 Engine
4006830 Engine Block 1975 casting
6322 Carter Thermoquad from a 1974 Dodge Truck
Speed-Pro Hypereutectic Pistons H116CP60
Compression Distance: 1.660"
Piston Head Volume: +5.00cc
Wrist Pin Style: Press-fit or Floating
Pin Diameter: 0.984"
Piston Ring Thickness: 5/64" x 5/64" x 3/16"
Stock 360 Rods
Lunati Voodoo Camshaft 60403
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Thanks for your help and looking forward to your responses. Cheers !
Stock 360 Rods
LSA/ICL: 110/106
