blue missile
RJ suggested some cheap insurance so here it is I used a couple pieces of 2"x3" tube stock
Andrew
Andrew
I like a ladder bar for the street not much tuning
KP,
RJ< how wide are those tires and how tall are the rims?
I have been doing all this work to get some 305s in there but I cant find a tire rim combo that will work.
Also I asked about the shock mounts, I still cannot get out the original ones without damaging them. Did you just start from scratch? If so I cant find an 11/16" bolt any where what did you use?
Andrew
Hey thanks for the info, how the hell does he turn that thing?
Andrew
OK so I will relocate the leafs temporarily in board to the frame rails. Then I will put in a 4link system made by RMS called a street linx. It is also set up for the inboard location. The next question is : is it ok to use a sway bar with a 4link, is it necessary, or harmful.
Next has anybody used this system?
Andrew
Not many options for that tall and that wide unfortunately. Nitto Invo comes in 294/45/18 but it's 28.5" tall (probably too tall for your ride height). You can do a 335/30/18 like the Demon pic'd, it's right at 26" tall. It's mini tubbed to the frame but not raised. It's on air so he pumps it up to drive
I wanted to run an 18" also, but they didnt have a tire tall enough to fill up the wheelwell enough for me, so I had to go 19".
I just saw that Nitto has a new NT555R II out in a 305/35/18......which may be what you are looking for.
here is another pic with the bracket on the rear.
Where can we find more information about this car?
Riddler
Riddler
the brackets you see are actually withing the wheel circumfrance. if the tire went flat the rim would hit the ground not the bracket.KP,
here is the info youi wanted. RJ said it was about $350 for the setup
http://www.1speedway.com/Swaybars.htm Link to the rear sway bar company.
MOPWR,
cool looking set up. one of the things I am fighting very herd to keep is ground clearance. your mounts would be to low for me, but great job fabricating them
Andrew
That's pretty cool! How are you doing the front mounting points? And the other two links? where/how do they connect(body and housing)?
http://www.popularhotrodding.com/features/0903phr_1971_dodge_demon/index.html
And
http://www.gforcedesignconcepts.com/gallery/DEMON
