Good job. Now if these numbers were the goal, the heads were the problem ...you removed them and stuck some way bigger better flowing heads on.. like night and day.
You could probably squeeze a little more out of those rhs, but you were already knocking on the door of running out of port volume.
Jmo.
Thanks. I'll agree with what you said to an extent but there were a number of factors that prevented that first version from making the power I hoped it would and it wasn't the heads. I didn't only change the heads for round two, the whole thing is different now. Regardless, if you go by the adage that says power = double the head flow then the IMM-RHS heads should support at least 600hp.
As I said in my first post, the goal 10 years ago with the RHS heads was 525hp. I would have done cartwheels if it made that. In reality there wasn't a huge difference between my stated goal and what it actually made but it was enough to make me want to go back and improve on it. I would have liked to have had some seat time with that version of the motor but it just wasn't meant to be.
The exhaust ports on the RHS heads were essentially untouched so figure the BPEs likely flow more on that side. I'm not sure if there is even room for a larger exhaust valve on the RHS heads. Maybe Brian will chime in here and let us know if that's the case but it's not terribly relevant to this thread. Either way, the RHS are good heads especially with the IMM CNC program - he had them flowing 293 CFM. They weigh about 800lbs each though so switching to aluminum castings shaved a bunch of weight off the front and up high. Trust me, that was not a small part of the decision to go with aluminum.
The intake port openings on the BPEs are larger than any head I've ever laid eyes on so that might account for something but I honestly don't know what they flow. Far as I can tell, Rod does not publish that info because it just creates unnecessary B.S.. It's not always about the biggest number anyway.
The pushrod pinch area is where the BPEs shine because they essentially have no pinch at all. The pinch is the Achilles heel of any standard-port LA head and is why the factory created the W stuff. If you think about it from that perspective, the BPEs are kind of the best of both worlds - basically no pushrod pinch yet no need for offset rocker gear.
All anyone needs to know is that the BPEs are very efficient and will obviously support well over 600hp. IMO they are the current pinnacle of standard LA stuff. If you want or need to make more power with a small block you're looking at much more expensive parts.
Maybe someone will crack 700 or more with a set of BPEs but that's going to take compression, a tricked out intake, big roller cam, 2 1/4" headers and an 1,150 Dominator. Race motor stuff.
