inkjunkie
Sitting here, cause that is all that I can do today & wondering about things. Lets say a guy was starting with nothing. And he wanted more or less just a toy. Gets driven on the street, sees the track several times a summer. Car will have an overdrive trans with a lockup converter so if 4:10s and a loose converter were needed would not be a big problem. Car will also have efi. You see the Mopar crate 440" small block advertised. What would it take to build one? Lets just say footing the bill for one of those Ritter blocks was tolerable as well. Would like to see the car run mid-low 10's. What cylinder heads? I do have a set of Brodix b1-ba castings but have been told they are not a good idea on a n/a pump gas type of build. I know building a forced induction motor would make this fairly simple, but lets leave that out of it for now. Mechanical roller is also acceptable. No matter which way I go custom headers will also be ok.......Not looking for a car with daily driver style manners.......:happy1:
